light copy pro 1106
  • aaahmmm
    • Aug 2009
    • 103
    light copy pro 1106
    i have light copy in the pro 1106 , when i do force toner supply the image became good for about 500k copy the start becoming light , also when i do toner supply i can found developer leak in the from the outer side of the DV unit .when i do TD sensor initial settings 2801 it complete with SC372 i changed the TD sensor , developer , set the image mode to pixel with no help .
    • 37556
    Re: light copy pro 1106
    Sounds like you may have a dirty ID sensor. Check SP 3001 and SP 3103. If SP 3001 is above 100 the sensor is dirty. If SP 3001 is normal but SP 3103 reading are all 0 or all 5, the ID sensor needs to be replaced.
    Setting the image mode to pixel count should be done as a temporary fix while you are waiting for a new sensor, TD or ID. Pixel count by default will slowly under tone the developer. This is to avoid over toning and toner spewing.
    • Iowatech
      Not a service manager
      • 3930
      Any chance they just are not be running the machine as hard as required? At first blush that's what I thought it was. But you know far more about the Pro line than I do.
