Have had two devices with similar issue.
MP C5503-Monochrome good. Magenta wouldn't line up. Firmware updated, ITB unit, all PWB's & laser unit recommended by Ricoh still wouldn't go through the SP adjustments correctly. Ran the SP adjustments in correct order.
MP C6003- Monochrome good. Middle looks great, ends are offset and internal skew. Line position adjustment- COARSE passes; FINE Tune fails. Firmware updated, ITB unit replaced. Ricoh went through with tech and ran all SP adjustments in correct order. Ricoh is recommending laser unit, but after the fiasco of the C5503 not being fixed, we are hesitant to order and replace the expensive part.
No error codes. All three of us are Ricoh certified technicians with a combined experience of over 60 years.
