loud noise. ricoh mpc2050
  • tullio
    • Feb 2012
    • 268
    loud noise.ricoh mpc2050 ,after 20-30 prints.replaced new fuser group, same problem. urgent
  • Elmo
    • Feb 2010
    • 541
    Re: loud noise. ricoh mpc2050
    try
    sp 1-121-001 set to 0
    sp 1-121-002 set to 0
    sp 1-121-003 set to 0
    I Used To Live To Fix Things Now i Fix Things To Live
    • tullio
      • Feb 2012
      • 268
      Ok .......
      • JDYAL
        • Sep 2008
        • 186
        Noise location? Type of noise? Is it grinding,squeaking or groaning?
        • JDYAL
          • Sep 2008
          • 186
          Also if you replaced the fuser components and you bent the fusing stay it will make a noise when reinstalled
          • tullio
            • Feb 2012
            • 268
            same problem????????????????
            • JDYAL
              • Sep 2008
              • 186
              I've had that noise from the compression springs in the drum unit.Sometimes its one drum and sometimes multiple. Have you ran each component individually through the output sp? Run just the drum motor for each unit and see if you get the noise.
              • tullio
                • Feb 2012
                • 268
                already 'done, no problem found.
                • sturmtrooper
                  Copier Combobulator
                  • May 2016
                  • 587
                  I've also had this issue. Solved by replacing the springs that press the lube bar onto the drum with new springs according to the TSB
                  Spring TSB.pdf
                  Here is the TSB.
                  • Codex
                    • May 2008
                    • 694
                    You can isolate the problem using output check, sometimes it's only one drum....try the spring TSB, o my case i solved the problem.....newer cpus have the new springs
                    now in italian:
                    Ciao , prova ad isolare il problema usando l'output check, spesso il problema si presenta solo in uno dei tamburi, nel mio caso ho risolto modificando la molla che tiene premuto la lubricant bar sulla spazzola.Comunque questo problema e stato risolto nei drum piu nuovi.
                    Memento Audere Semper
                    • tullio
                      • Feb 2012
                      • 268
                      I do not know. thank you. now I try.
