MPC02 series drum mods
  • tufbnme
    • 493
    Did a search but didn't find anything about modifying the K pcu to use in the color slots on the MPc3002/3502/4502/5502 series.
    I have found that you cannot use the B2242042 in them though.
  • LNorris
    • Sep 2008
    • 645
    Re: MPC02 series drum mods
    not mine, but got it from here
    • tnelson
      • Aug 2016
      • 21
      to use the b224-2042 pcu on an 02 series you must first break off the metal pins at the back of the machine. we built a little tool for this but i have had to do it with just pliers. if you shine a flash light inside the copier with the pcu's and the itb out you will see what i'm talking about. there is a pin for each color pcu. just move it side to side till the tin lets go. then you grind the left side of the connector on the pcu ( part with the little metal pin in it) once you've ground down that area and got the pin out, you simple install as usual. it works great and saves you darn near a hundred dollars every time you have to replace a color pcu.
      the black cannot be modified. you must use the proper pcu.
      • sandmanmac
        • 3981
        One could also just refer to the cheat sheet proivided by LNorris above ....with cross reference, P/N's, & pictures
        • tufbnme
          • 493
          Both are very helpful, Thank you
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            You can use both 2042 and 2256 type drums for all colours, on the 02s. Just make sure you swap the front cover plate, it has a locator pin on the bottom that is in a different position (if you are replacing BK).
            2256 is rated higher, at 120k, but is a bit more expensive.
            • Imprestik
              • Aug 2012
              • 297
              I use the maintenance Kit 830's which is the cheapest option of the lot.
              Only modification required is to swap the TD sensor off the original dev unit and the face plate.
              Along with the transfer unit maintenance kit and fuser maintenance kit you have yourself a really cheap full PM
              • tufbnme
                • 493
                Which kit is it? I only find a fuser kit.
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  This is a mod sheet that we use in house.
                  It assumes that you already know how to perform the mods and is more of a guide for which units fit into which machines.
                  It was made for our bush techs...hence it's a little bit basic.
                  • sturmtrooper
                    Copier Combobulator
                    • May 2016
                    • 587
                    Why does your guide say not to empty the waste toner bottles on 03 and 04 series machines?
                    • Imprestik
                      • Aug 2012
                      • 297
                      Just order the maintenance kits for the SPC830DN, the K PCDU, colour PCDU's and transfer PCDU
                      • TonerMunkeh
                        Professional Moron
                        • 3865
                        We've had instruction never to empty these waste bottles, just replace them.
                        Hit it.
                        • sturmtrooper
                          Copier Combobulator
                          • May 2016
                          • 587
                          Yeah I don't think any of the waste bottles are supposed to be emptied, but my company is cheap.
