pro8110
  • slot
    • Jul 2008
    • 341
    pro8110
    has anyone been having problems with sc382 we have changed the drum and dev the sensor is clean but first thing each day it comes up any advise please
    • 37488
    Re: pro8110
    SC 382 is the drum potential sensor not the developer sensor. Replacement is covered in the service manual. Potential sensor.
    • nikeccc
      • Aug 2014
      • 5
      Re: pro8110
      Hi everyone. I'm having the same problem with a pro 8120S. SC382 occurs. I have replaced drum potential sensor, drum, PCDU, IOB and still nothing. I will try to replace harness, it is the only thing left. Did anyone solved this? Thanks
      • dade80vr
        Re: pro8110
        Hi. Did you solve it? Same problem here: SC382-01.
        Replaced drum, charge corona unit, potential sensor, IOB.
        Please help me! Bye.
        • dade80vr
          Re: pro8110
          SAME problem here, what is the solution?
          I have just ordered controller NVRAM.. is right?
          • dade80vr
            Re: pro8110
            Hi guys.
            Problem solved with development unit replacement: the lower develpment roller was dirty due to a strong old developer "film" that drain overcurrent to potential sensor.
            You also could clean it with sand paper but it is recommended to replace.
            Bye.
            • rhpardo77
              • Dec 2019
              • 9
              Re: pro8110
              Hey guys..
              I keep getting an SC382 error code on one of our Pro 8100s machines.
              I've tried replacing:
              -potential sensor
              -drum
              -drum cleaning unit
              -developer
              -development unit
              -charge corona unit
              -IOB
              -laser
              ...among other unrelated parts, but still no luck in clearing the error.
              All these parts seem to be good since I've tested them on another 8100 with no issues.
              I'm not sure where else to go from this point. Any suggestions on what else I could try?
              Thanks in advance!
              • davel
                • Oct 2011
                • 1104
                Re: pro8110
                Old dead thread but try fitting new parts.
                  • 37488
                  Re: pro8110
                  He already posted a new thread. That is why I didn't chastise him yesterday.
