Ricoh MP C3000 print black fade position
  • kobiemexx
    • 6
    [Misc] Ricoh MP C3000 print black fade position
    Ricoh MP C3000 print black fade position as in pictures
    I have already replace the Black drum but it just the same result
    I will be grateful for any help
    2. I have a second MP C3000 , I cant access System Settings
    I think it was used just for coping before I bought it
    I cant even see the System Settings, from what I have google
    I need to format the HDD I have tried SP SP5832 , it did format the HDD but I still don't have full access to admin tools
  • gkalman2004
    • 157
    Re: Ricoh MP C3000 print black fade position
    Try to print from By-pass Tray if the paper is thick and will be ok.
    If you use normal papers try to clean ID sensor, density sensor or you have a deformed center area on the image transfer belt
    Clean the laser unit
    Try also to execute the music sp2-111-3/2/1
    (if you already changed the whole black unit pcu and drum you eliminated the posible charge roller problem)
    The system settings in the UP mode can be reset to their defaults. Use the following
    procedure.
    1. Press User Tools/Counter .
    2. Hold down # and then press System Settings.
    (You must press # first.)
    If you don't see at all the sytem settings you must have administrator rights on the machine
    in this case you can try a
    Software reset
    You can reboot the software with one of the following two procedures:
    1. Turn the main power switch off and on.
    2. Press and hold down ./x # together for over 10 seconds. When the machine beeps once, release
    both buttons. After “Now loading. Please wait” shows for a few seconds, the copy window will open.
    The machine is ready for normal operation
    Or gain acces with login as supervisor and no password to reset admin password.
    or default log in administrator with no password
    • NeoMatrix
      Senior Tech.
      • 3513
      The fading on the scan images you supplied, looks very much like a PCU charge roller issue.
      I assume the paper path is LEF...
      You may have to get a service Technician in to clean and service your machine(s).
      HTH
        • 37653
        Assuming that the paper is fed LEF, you either have a dirty laser shield glass for the black or you need to replace the black development unit.
        • kobiemexx
          • 6
          Thanks soo much Guys I will try tomorrow when I get to work
          • Mark Bbb
            • Jun 2012
            • 1662
            F.U. belt (deformation) could case this too...
            What was the solution, would you be so kind telling us?
            • mikadonovan
              • May 2008
              • 2931
              This is what it looks like. As far as your other machine, log in as a supervisor and change administrator UN and password and disable administrator authentication.
              NEVER ASSUME ANYTHING
              • kobiemexx
                • 6
                Sorry I have not have find time to write, the problem is the same and My big issue is MP C3000 not finding black toner for some what reason
                I have 3 MP C3000 now , all the same Problem, this with the fade issue is also reporting black toner issue , I just don't know how can 3 Machine bringing the same Error
                the third one we change the drum it work for a few days
                • gkalman2004
                  • 157
                  The first it is easy your toner not reach the pump unit, can be the pump unit or the sensor nozzle or the connection tube between them .
                  First take from one unit one working pump like magenta or cyan and change on other unit the bad black pump unit with the good magenta or cyan (the yellow it is a bit different but also can fit in)
                  open and close the door more times to execute toner supply or execute sp3016 forced toner suply
                  if not work you must open the back cover and check under the pcb's the end toner sensor nozzle and the tube for strengthened toner
                  Clean up the sensor the nozzle and the tube, open the tube clip and "shake up" the tube (around AW020185)
                  About ~30 min work to fix all the problem.
                  • Iowatech
                    Not a service manager
                    • 3930
                    Thanks to my current internet connection (which is "Plan B"), my like button only works randomly. So consider this a like marker, and that once I get back on my primary connection I will actually like that post. Sorry.
                    • ReyTech
                      • Aug 2016
                      • 8
                      Replace the black toner pump.😀
                      • logrady2331
                        • Feb 2011
                        • 301
                        I'm going with slimslob on this one. Clean the lsu slit glass......If you are an end user that's the blue wand thingy inside the front door.
