Scanning Transmission Error but file pass through corrupted.
  • aviso66
    • Dec 2012
    • 202
    Hi
    I have just encountered this problem recently. I am not sure what is the problem here. The laptop is using Lan network and perform scanning to folder from a ricoh machine. However, it says transmission error. But I test the scan path, it succeeded. However, file still pass through and when I try to open it. It says corrupted.
    On the other hand, when i try using the Wifi. the scanning was ok.
    Any suggestion?
    • 37575
    Re: Scanning Transmission Error but file pass through corrupted.
    Bad cable, bad port on the switch/router/hub.
