Generic toner
  • Geo
    • 662
    Generic toner
    Hi Folks..
    Any thoughts on generic color toner, specifically for the SPC- 232Dn color printer. I know that generic will work on some but not all printers and my experience on Ricoh boxes is very limited . So any help would be much appreciated.
    Thanks Much
    Geo
    P.S. And the B.W . desktop printers.
  • Users Tech
    • Nov 2013
    • 85
    Re: Generic toner
    generic = headache.. to be fair, only a few are ok..
      • 36200
      Re: Generic toner
      Things to think about on generic after market supplies.
      1. Quality control usually does not exist
      2. Quantity of toner in a cartridge usually is less. Cartridge price may be less but cost per page may be higher.
      3. Cost to maintain copy quality normally will go up
      • jonhiker
        • 661
        Re: Generic toner
        stick to OEM, generic may be cheaper, but oem will be better for the machine.
        • Polarbear
          • Feb 2012
          • 1070
          Re: Generic toner
          From personal experience, you can take your chances with b/w toner. but STAY AWAY from generic colour toner!
          It is an absolute nightmare, and trying to repair a machine that is misbehaving while using generic colour toner is a road you don't want to be on!
          +1 on all the previous posts that cheap now expensive later - for sure!
          This applies to inks as well. Have had generic inks that won't even report when they are empty, causing false service calls, and possible damage to the device! Good luck proving that!
          Press the GREEN button!!
          • nmfaxman
            • 1705
            Re: Generic toner
            Penny wise, dollar stupid.
            Takes out toner pumps, DV units and poor CQ.
            Color toner is not the exact same color as OEM, therefore color blending is not accurate.
            • Geo
              • 662
              Re: Generic toner
              Hi Folks
              Thanks for everyone's input. I am aware of the risks of generic toner for Kyocera products , but I just didn't know how well Ricoh products tolerate generic toners and how well they are made. I was hoping I could at least use generic in monochrome printers for the remainder ( one year) of an inherited contract. Unfortunately everyone gave me the wrong () answer.
              Thanks for everyone's help.
              Geo
                • 36200
                Re: Generic toner
                Originally posted by Geo
                Hi Folks
                Geo
                If you a non Ricoh dealer/third party service organization and you want to use generic in Ricoh B/W to get you to the end of a contract you have picked up, go with NA Trading. Their toner and developer are on a par with Ricoh in both quality and dealer cost. It is advisable to go to their developer as soon as possible as their toner works best with their developer.
                • fshead
                  • 2356
                  Re: Generic toner
                  I AT times have used some generic toners and stopped on the big b/w 60 plus cpm boxes and
                  i treat non OEM toner the same as buying cheap no name gas.
                  it might be ok till i start having "wierd issues"and i cant rule "IT" out as the cause of my new
                  problem.
                  Also on the cheap accnts that will not buy from you OEM and buy online non OEM,
                  I am not making anything on supplies so when i get a copy quality issue I have no problem
                  changing drum blades and or drum units..
                  • sturmtrooper
                    Copier Combobulator
                    • May 2016
                    • 589
                    Re: Generic toner
                    problem.
                    This is why our maint contracts require them to get OEM toner directly from us, the cost of which is included in the contract. If they don't want to do that they can be a billable account and pay hourly plus travel charges. Which given the rural nature of our area can get expensive.
                    • logrady2331
                      • Feb 2011
                      • 301
                      Re: Generic toner
                      Really depends on volume for color. My low volume color accounts (less than a thousand per month) run N/A Trading aftermarkets. We run OEM on ALL black toners, regardless of model.
