SD Cards
  • venluckey
    • 36
    SD Cards
    I have seen many people talk about SD cards on here.
    I know about:
    Print/Scanner
    Postscript
    Java
    Has anyone run into a SD Card that has just SD logo on it and numbers (2-0805) (B8375001P)
    It has files on it, they have the (.lic) file extension and one would assume is licence keys.
    It also has language files, is just a storage medium for the copier?
    Sorry don't know what Model it came out of, we recycle them when they break and so we pull the SD cards and HHD/SSD out of the machines.
    Any Insights?
  • DougD
    2020 Retired
    • Sep 2016
    • 76
    Re: SD Cards
    The part number is for the MP C4500 print/scan.
    I've no idea what files should or should not be present on the card.
      • 37532
      Re: SD Cards
      The .lic files would be the license files for the Print/Scan function. The other files should be the program files for print/scan.
      • sturmtrooper
        Copier Combobulator
        • May 2016
        • 587
        Re: SD Cards
        As was mentioned it is the printer/scanner option card. The card is serial number locked to the first machine it was put into and will not work with any other machine.
        • Iowatech
          Not a service manager
          • 3930
          Re: SD Cards
          If you don't actually need that SD card, clear out everything on it and then use it for firmware updates. That's what I did with that type of SD card anyway.
          • sturmtrooper
            Copier Combobulator
            • May 2016
            • 587
            Re: SD Cards
            I've done the same with some. I think it only works with Java cards as the rest tend to be permanently write protected. Cheap way to get a SD that's only a few hundred MB if you have a picky machine.
            • Iowatech
              • 3930
              Re: SD Cards
              This just might be for the SD cards from older machines, but I found that pretty much any of them work perfectly for firmware updates, unless they were actually damaged in some fashion anyway. I think some of the more difficult ones just need to be formatted with the Panasonic utility first. I don't have the bookmark for that anymore in this browser thanks to a brain fart, but I think I still have it in one of the other browsers on this machine, so I'll look for it if you want. I imagine as much irritation as that caused back in the day though, others have that at the ready right now.
              • copyaction
                • Oct 2007
                • 991
                Re: SD Cards
                here is link for Panasonic formatter (thanks goes out to slimslob):
                SD/SDHC/SDXC Memory Card Formatting Software | Download | SD Memory Card | Digital AV | Consumer Products | Support | Panasonic Global
                • techno77
                  • Jul 2014
                  • 7
                  Re: SD Cards
                  SD usually means SanDisk and is usually a storage device,
                  you can use it for firmware, updating java, media library etc... usually the card is labeled if it has proprietary software already loaded on it, back it up and use it as needed. Just my opinion. Good luck!
                  • Iowatech
                    • 3930
                    Re: SD Cards
                    Well, maybe to SanDisk employees it does, but to the rest of the world it means this: https://en.wikipedia.org/wiki/Secure_Digital Here's their home page: https://www.sdcard.org/
                    • sturmtrooper
                      Copier Combobulator
                      • May 2016
                      • 587
                      Re: SD Cards
                      Originally posted by copyaction
                      I have that program, it's actually from the SD card association, still doesn't touch the ones that are permanently write locked. I just tried with A DOSS and Print/Scan card.
                      • logrady2331
                        • Feb 2011
                        • 301
                        Re: SD Cards
                        Download ans use Ricoh's SD card formatter.
                          • 37532
                          Re: SD Cards
                          I don't know about ths DOSS card, but the Print/Scan card should not be permanently write protected. If they are, you cannot update printer firmware. Check the lock slide switch on the card. I had a Pro 1107EX giving me a download error E44 last week because the card lock was in the lock position.
                          • sturmtrooper
                            Copier Combobulator
                            • May 2016
                            • 587
                            Re: SD Cards
                            I checked. It's a type 1357 card. Still won't format.
                              • 37532
                              Re: SD Cards
                              If the little white slide switch on the edge of the card is not in the lock position and the card still will not format, the card is defective. One other thing, not all cards support the FULL (Erase) format option. You can only do QUICK and FULL (Overwrite). You can also try MiniTool Partition Wizard.
