Hi,
I having a hard time trying to install a hdd (320gb 2.5"). As I don't have the special power cable below, I'm using an external PC PSU.
The user manual doesn't explain how to prepare the disk. Tried to add without any partition without success (checked the "device connection" on the "configuration page").
Do I have to format it? What type of partition? Thank you for your help in advance.
I found the Service Mode (SP mode) code, but the formating failed:
Press "reset", than 8-0-6-1-8-2 than hold "Clear" for a few seconds.
On Service mode, select 5832 - HDD
