@Remote Enterprise Pro
  • jsteg1981
    • May 2016
    • 13
    Hey all!
    First, I'd like to start by saying that I have no certifications and that I was kind of just thrown into a role of supporting this solution. I used to work for a company that uses @REP to monitor their Ricoh fleet in North America. I have since left that company and their preferred IT vendor is a client of mine. Well, they found out that I am now freelancing and still need me to support their @REP server.
    The problem I am facing is that a small handful of these machines are not registering correctly with @REP. I am not sure of the information you all need to assist, so please let me know. I have attached a screen shot of what I am talking about.
    I have confirmed that SNMP is enabled. They use SNMP v1. Out of a little over 1000 machines, there are like 10 or so that are doing this. I have confirmed with their NOC that these locations are not blocking any SNMP ports on the VLAN that these machines are on. Ricoh has given me a tad bit of help and one of their suggestions is to send someone to site to clear SNMP at the machine. Did that and nothing.
    I greatly appreciate any help I can get.
    Thank you in advance!
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: @Remote Enterprise Pro
    • The Printer is directly on the network, not connected to a print server
    • The Printer has SNMP enabled
    • The Printer has public as it's SNMP community name
    • The Printer is on a network segment that is being discovered
    Hard to say with limited information at hand.
    Can you ping and get to the web interface of these printers from your location?
    • jsteg1981
      • May 2016
      • 13
      Sorry for the delay.
      It is directly connected to the network. It is being NAT'ed. No print servers anywhere. I can ping it, access the web interface and SNMP is enabled. It has a public IP and SNMP is NOT being blocked. I don't know if it is is on a segment that is being discovered. We manually add each Ricoh so that may not apply? It also has the community name. In this case, we use RSMWDMEX.
      Aside from "deleting" the printer, is there a way within @REP to completely remove anything and everything regarding this printer? Basically make it forget about this machine completely?
        • 37515
        If it is on a public IP address, then it most likely is not on a segment that is being discovered. A public address is accessible to the entire internet. It needs to be on a local IP address, that is unless you want to try to discover ever printer in the world, which could take a few days.
        • jsteg1981
          • May 2016
          • 13
          I understand the difference between public and private IP's. This company has the @REP server on a machine in the UK, while these machines are all in the US and Canada. They have no direct VPN tunnels to that server, so the private IP's will not work. We have been manually adding each Ricoh to the server via the public IP for years.
          As I stated in my first post, there are a little over 1000 printers registered with this solution and about 10 or so that are not registered correctly. All of the machines that are registered with this solution are registered via their public IP addresses.
          I wish I knew what more information I could provide to help more, but this is not my specialty...
          Again, thanks for the responses. Hopefully we can figure this out soon. Unfortunately, since this company is not paying for this solution, Ricoh provides limited assistance.
          • jsteg1981
            • May 2016
            • 13
            Here is a screenshot of the @REP. I have blacked out the IP's, but left a little showing to show we are using the public IP's. Hope this helps.
            Oh yeah, my count was inaccurate. Over 30 that are not registering correctly.
            • Gamut
              • 216
              Are you sure this is pro and not a basil box, as your 2nd image reveals 1-1000/1025 items showing
              Which indicates to me you can only log max 1000 devices.
              • jsteg1981
                • May 2016
                • 13
                Here is the next page. 1001 through 1025
                  • 37515
                  How much memory is installed and are they using the optional @Remote Connector. The service manual specifies that the maximum number of devices to be managed is 100 standard and 1000 when optional DIMM is installed. White paper specifies that memory requirement is 1GB or more or 2MB when managing 1000+ devices or 5000 when the optional @Remote Connector is used.
                  • jsteg1981
                    • May 2016
                    • 13
                    Again, my apologies for the delay. I have been busier than a one eyed cat watching two mouse holes.
                    No @Remote connector. The server has 4 GB of RAM.
                    • Gamut
                      • 216
                      As slimslob advised above you need @Remote connector for more than a 1000 devices.
