C5503 /w Fiery E-22C - Max print size
  • Stormhammer
    • 150
    I have a customer attempting to print banner sizes from the bypass up to 48 inches long, as the machine allows. However, when setting document sizes through the Fiery print preferences the max custom size is only 23.6 in length. I have patched the Fiery up to date, but the max custom size is still limited to this. Am I missing something?
    • 37375
    Re: C5503 /w Fiery E-22C - Max print size
    Change SP 5150-001 to 1. This changes the maximum length for the bypass from 600mm, 26.3 inches, to 1260 mm, 49.6 inches. Apparent the fiery picks this setting up from this setting. If you have access to TSRC there is a video nugget.
    • Stormhammer
      • 150
      Thanks as always. You are truly an unending source of knowledge.
      • sturmtrooper
        Copier Combobulator
        • May 2016
        • 587
        This is one of those fringe things that is mentioned in the training for the machine through Ricoh, but is otherwise rather obscure.
          • 37375
          I found it in the video nugget on TSRC.
          • Stormhammer
            • 150
            This was already set to 1. The Fiery is still limiting max length on the bypass to 600mm.
            • TonerMunkeh
              Professional Moron
              • 3865
              You may have to use the GW controller for this job and possibly tell the customer even though this machine has a Fiery, it is by no means a production machine and shouldn't be expected to work as such.
              Hit it.
                • 37375
                There is a video nugget "How to print banners on an E-22C Fiery" on TSRC that says to use the print driver for the E-22B fiery for a Pro C5100.
                If you wish to use the GW Controller, use the PCL6 driver for the SP C831DN. This is from another video nugget, MP C5503 (D146 series) Banner Printing.
                • Stormhammer
                  • 150
                  This discussion is entirely a necessary one. However, I've been instructed to restrain myself when speaking already on this account.
                  • Stormhammer
                    • 150
                    Thank you for passing that along. I havent been able to review the video nugget yet but i will as soon as i am able to. Ive been in remote mountainous regions all day with almost no internet or cellphone service.
                    • Stormhammer
                      • 150
                      Installing the Pro C5100S E-22B Fiery drivers for PS fixed it as the video nugget stated.
                      • anpetros
                        • May 2011
                        • 43
                        I need your help on something concerning the long paper size.I have an mpc 7501 with an E-7200 fiery.When i enter 600mm long paper (which the driver lets me to) the display says: ''invalid paper size was specified.Press reset to continue''. Of course i have set the sp 5051 to 1 and all the patches to the fiery controller.If you have any idea what i am missing would you be kind enough to share it with me?
                        • davel
                          • Oct 2011
                          • 1095
                          You are missing a clean machine, get rid of the toner spitting beast.
                            • 37375
                            This is a 3 year old thread. Start a new one grave robber.
                            • Stormhammer
                              • 150
                              This thread is so old I don't even work on MFD's or printing equipment anymore.
                              That's pretty old.
