Help
  • ahmed_dcc
    • Sep 2012
    • 36
    Help
    Hi
    I have a photograph Ricoh MP301 there is no English language How do I add the English language and how to get the service manual.
    Thanks to all
    • 37556
    Re: Help
    You can select the languages available when you install the Language firmware.
    • ahmed_dcc
      • Sep 2012
      • 36
      Re: Help
      Thank you
      How it's done and where to get the firmware ?
        • 37556
        Re: Help
        You have an authorized Ricoh service tech install it for you or if there is none in your area, contact Ricoh support directly and see if they will send you the firmware and instructions for installing it.
        • ahmed_dcc
          • Sep 2012
          • 36
          Re: Help
          Thank you very much
          • tonnerboy
            • May 2011
            • 212
            Re: Help
            I think there is a misunderstanding.
            you do no need to install firmware on MP301... you just need to select the language in the administrator tools.
