Mp 5000 error code sc440 sometimes
  • renjith
    • Jul 2015
    • 3
    [Error Code] Mp 5000 error code sc440 sometimes
    Dear all,
    One of mp 5000 machine showing error sc440 sometimes, i changed drum and developer unit together , Also i changed transfer belt unit and power pack unit, Pls suggest guide anybudy have suggestions
    Regards
    Renjith
  • gkalman2004
    • 157
    Re: Mp 5000 error code sc440 sometimes
    Check and change the harness
    • meldwo
      • Feb 2012
      • 36
      Transfer belt bias error
      The feed back bias from the transfer belt is more than 4V for 60 m sec while the transfer belt bias is output. The A/D conversion level is 20 or less for 60 msec. The PWM duty is 24% or more for 60 m sec.
      Causes
      • zaheerkunri786
        ricoh mp 5000 sc 868 erreor and also show the message memory error
        • keithxxiii
          Just a tech
          • Nov 2014
          • 468
          Start a new thread..
          SD card inserted is faulty or your controller is faulty
          Aye! Cut the crap
            ricoh mp 5000 sc 868 error and also show the message memory error
            your issue has nothing to do with an SC440 ... please start your own thread or search CTN for your topic
            • bob marley
              • Jan 2012
              • 1339
              * SD card not inserted correctly
              * SD card defective
              * Controller board defective
              Live for yourself and you will live in vain. Live for others, and you will live again
