Ricoh mpc 2050
  • tullio
    • Feb 2012
    • 268
    Ricoh mpc 2050
    Problem ricoh mpc 2050. Black .[ATTACH=CONFIG]34429[/ATuTACH]
    Urgent
  • DougD
    2020 Retired
    • Sep 2016
    • 76
    Re: Ricoh mpc 2050
    Is that a print job or a copy?
    If it's a print job, I would say it's a driver issue.
    • tullio
      • Feb 2012
      • 268
      Re: Ricoh mpc 2050
      In Print.
      • sturmtrooper
        Copier Combobulator
        • May 2016
        • 587
        Re: Ricoh mpc 2050
        Originally posted by tullio
        In Print.
        uninstall drivers from PC, install latest drivers from Ricoh, make sure it's not running some windows class driver.
          • 37474
          Re: Ricoh mpc 2050
          If it is only printer, clear printer function memory and format printer portion of HDD. Otherwise, BICU or laser.
          • tullio
            • Feb 2012
            • 268
            Re: Ricoh mpc 2050
            Driver.ok ok ok.Thank .
            • Polo-022
              • Sep 2007
              • 484
              Re: Ricoh mpc 2050
              Dimm's. If they do exist, reseat them...
              • Elmo
                • Feb 2010
                • 541
                Re: Ricoh mpc 2050
                When you print test page from sp mode do you get the same fault
                I Used To Live To Fix Things Now i Fix Things To Live
