ok, printer is showing open front cover and remove paper.
when in the sp mode, i cant get the cover switch to change states (i just put a new one in) and no change. the manual says its a interchange switch, mounted on the front cover (photo sensor).
looking at the manual it appears to me a aw010118 sensor, i went to put that in and its not the same sensor. the 0118 appears to be a fuser exit sensor, but the diagram is throwing me off.
anyone seen this error and propose a resolution?
thanks
thanks
