sd card ahthentication failed in mp9000
  • vargue
    • Oct 2011
    • 404
    hi guys i had this message i installed a new printer/scanner sd card original.with known that machine worked before without that function. is upgrade is a clue.
  • adween shaari
    Senior IT Technician
    • May 2012
    • 47
    Re: sd card ahthentication failed in mp9000
    Have u confirmed that sd card okay or not?
      • 37652
      Did you install the entire Printer/Scanner kit or just the SD card and the key tops. Printer/Scanner requires the installation of additional memory that is included in the kit.
      • vargue
        • Oct 2011
        • 404
        additional dimm already placed in sluts. 2 ram already exist .just sd card
          • 37652
          Printer/Scanner requires 2 128MB DIMM and 1 256MB DIMM in addition to the memory already existing on the machine.
          memory.pdf
          • vargue
            • Oct 2011
            • 404
            today i upgrade firmware and the same issue still appeared .i swapped sd from another machine. the message gone .but printer and scanner application not appeared .i did 5985 and all being correct. what's the point . all dimm ram 256 and 2 ram 128 in mother board.
            • Counsel
              • Aug 2011
              • 529
              Does the SD card have a "lock" on it, I haven't had to install one but just curious if it is in locked position if that would matter.
              • vargue
                • Oct 2011
                • 404
                it's on unlock position .
                  • 37652
                  Is that the total RAM on the board or just those added for the Printer/scanner function. When you added the RAM did yu do so as shown in the service manual? The added memory has to go in specific locations as shown in the service manual.
                  • vargue
                    • Oct 2011
                    • 404
                    thank yo guys lane board is not exist.
