Ricoh lcd issue.
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Ricoh lcd issue.
    The machine is a Lanier LD533c. The customer called saying the control panel wouldn't work. The screen was illuminated but blank with a thumbprint size of blue pixels in the upper left hand screen. I swapped the lcd with one from a parts machine. I get the same result without the blue pixels. The touch screen works. I was able to print a meter by hitting where the buttons should be. I called tech support and their advise was to start with the cable that the panel plugs into, then the board it plugs into, then the next board and so on. Problem is that I don't have a parts machine with boards. Has anyone seen this and can you point me to a more specific resolution.
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: Ricoh lcd issue.
    Fix have you tried reloading the LCDC firmware?????????
    Mystic Crystal Revelations
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      No, didn't know about it. Tech support never mentioned it. Thanks.
      • qbert69
        • Mar 2013
        • 1152
        Ok. You replaced the LCD. It works.
        Did you calibrate the Touch Screen overlay?
        1993 + C/S + C/S hold
        REACH FOR THE STARS!!!
        Konica Minolta Planetariums!
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          As far as the firmware goes, it did not occur to me that Ricoh firmware has to be loaded using the touchscreen until I was writing it. I called the company we have do our board repairs and got the info I wanted. That the characters I am missing on the screen are put there by the board the screen plugs into. I kind of assumed that, but wanted a definite answer. I did not swap it because the only match is a brand new machine and they won't let me touch it. I will order that board. The guy at Hytec said this is a rare problem.
            • 37533
            You can load remote firmware using WIM.
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              I was looking in the manual for another way to load it, and the obvious escaped me. None of the tech support I talked to thought it would be firmware related. Of course I should have know that already. Been a stressful week. A 5 foot long postage machine at the DOJ can really mess your week up. I think my IT dept should have clued me in when I ask. They do this shit all the time. My week has consisted of a Bz 42 that only works when I stand beside it, quits when I leave. A Bz 552 with a noise I can't find. Postage machine I only see once a year. Then there are the Dell and Lexmark printers at my table. Then there was the depressing trip to Lumberton. That is the town I posted a pic of in Random thoughts thread that looks like someone built a town in the middle of a lake. Place looks like a third world country now. Anyway, thank you guys for responding. I will update when fixed.
              • fixthecopier
                ALIEN OVERLORD
                • 4713
                I really feel dumb about the firmware issue. My only excuse is that after all these years of working on machines for the military with no internet hook up, I got used to doing everything at the control panel. It's just a lame excuse, but the only one I have for being slack.
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  You're not dumb. Not everyone can remember everything they are ever taught. If we could, we would have brains the size of a car and would definitely NOT be copier techs.
                  Hit it.
                  • fixthecopier
                    ALIEN OVERLORD
                    • 4713
                    The issue with the LCD was resolved by changing the board that it plugs into, I forget it's proper name. It was pretty much plug and play. Did not need firmware or any calibration. Ricoh and Hytech tech support both said this was an issue that was not that common.
                    • sturmtrooper
                      Copier Combobulator
                      • May 2016
                      • 587
                      I had to replace a touch panel on a 3025 and I put it in upside down twice. In a row. I felt special.
                      I think the board you are thinking of is called the LCDC board. Or something similar.
