Copies card SD to another
  • ahmed_dcc
    • Sep 2012
    • 36
    Hello everyone
    After greeting
    I'd like to know how to copy the contents of Memory Card for machine Ricoh on the last card the same size and specifications to run another machine without a card
    Thanks to all
  • sandmanmac
    • 3979
    Re: Copies card SD to another
    Can't be done.
    Order one, look for one on Ebay, or post the model you're looking for in this forum:
    http://www.copytechnet.com/forums/fo...ade-or-wanted/
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Somebody's always trying to cheat the system.
      • ahmed_dcc
        • Sep 2012
        • 36
        Sorry, but this is not circumvent any system but when I import complete machines contents and discovered that not have its own operating card must be on I'm looking at alternatives in order that there is no loss if I can buy the card from anywhere without a copy to have done, but I can not find the source does not There's no one tells you the source every person has information retained for himself Is there a solution to tell it to me instead of anger and intolerance
        Thanks to all respond and interact very sorry to prolong the talk
        • Elmo
          • Feb 2010
          • 541
          You have not said which model machine
          some models don't have print/scan as standard
          it is an option
          I Used To Live To Fix Things Now i Fix Things To Live
          • Polarbear
            • Feb 2012
            • 1070
            Wow! Cool the rage man!
            The more info you give in your question the better we can try and assist.
            We are all techs doing our best to share information - mainly based on what you ask.
            The less info is given - the more likely you are to get the response you got - it is that simple!
            Press the GREEN button!!
            • ahmed_dcc
              • Sep 2012
              • 36
              Thanks to all
              Models required to have a card (MP5000 - MP161-171-201)
              • sandmanmac
                • 3979
                Thanks to all
                All of those machines require a combination of the following, in addition to the SD card, for it to function: Additional circuitry, Memory Dimms, Hard drive, Keytops (buttons)
                Example Of MP161 Kit: 413639 Print Scan Kit Type 161
                • ahmed_dcc
                  • Sep 2012
                  • 36
                  Thank you!
