i posted a few days ago about background. this is a Lanier LD 235, but uses the same drum etc as the aficio 2035, 3045 etc. the machine has a new drum, blade, PCR, brush, fuser rollers. i have removed the mag rollers and cleaned them, verified the erase lamps are working.
I did find a strange phenomenon though. as I said, the heavy background, and the reverse double image isnt on the edges, and also only on the top and bottom third of the page. the center of copies is fine.
I made a strange discovery. when the paper is loaded 8 1/2 x 11 the copies are perfect. if the paper is loaded 8 1/2 x 11R in either drawer, it does this. and the first copy is always fine. if you run 5, it gets progressively worse.
this just doesnt make any sence unless there is some setting to adjust that size letter long to change the charging parameters for ? special paper.
does anyone have any ideas what could be causing this? have a nice day, Jim
