do wee need to initialize after reassemble back the lens block and ld unit
  • hsh6049
    • Jul 2012
    • 64
    photocopy come out with this image....been exchange the drum unit, developer tank and transfer unit still same problem but print out ok
    so i check lens block and ld unit after assemble back photocopy come out wilth clank copy
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: do wee need to initialize after reassemble back the lens block and ld unit
    It would be helpful to know what machine model and what exactly you did to the laser unit. There isn't much you are supposed to disassemble on the laser unit though.
      • 37062
      Or the lens block assembly.
      • hsh6049
        • Jul 2012
        • 64
        hi currently using mp6500 i just loosen the two screw of laser diode unplug the cable ...then plug it back2016-11-08 08.33.52.jpg then photocopy still with blank copy but print everything ok.
        after print about ten thousand copies the machine appear sc220... wht should i do
        • hsh6049
          • Jul 2012
          • 64
          mp6500 ,i just unplug the cable and plug it back
