ricoh pro907ex folding top corner when duplexing
  • salvador zambrano
    • Nov 2011
    • 25
    I have ricoh pro907ex copiers that are folding corner(corner is folded back towards side2) on non operator side when duplexing. I have taken duplex unit completely apart and did not find any problem with any parts in the duplex unit. the problem goes away for a few days then late it starts doing it again. I also rechecked fuser exit and found no problems in those parts. Any help on this issue will be appreciated. Thanks.
    • 37533
    Re: ricoh pro907ex folding top corner when duplexing
    I have had the ribs on the plastic guide plates and cause this. Usually smoothing it down will correct it with out having to replace.
    • Codex
      • May 2008
      • 704
      Ckeck the inverter solenoid....i had the same in one machine , the solenoid works intermittent causing the dog ear passing the inverter guide
      Memento Audere Semper
      • jmhashmi
        Technical Supervisor
        • May 2009
        • 62
        Codex is right. Try cleaning with Alcohol or replace if cleaning does not help.
        One more thing try to reduce Fuser temperature.
