MP 4001
  • tcypy1961
    • 773
    MP 4001
    customer called about noise that I only heard once, sounded like the transfer belt seizing up which I've heard on other earlier Ricoh models or the limit pulley;
    any heard anything like this from this model, first I've had.
    Thanks!!!
  • jonhiker
    • 661
    Re: MP 4001
    check the PCU, the toner recycle auger sometimes get clogged up and make a chattering noise. you can try to clean it... be prpared to replace the unt.
    • imaginemoko
      unTrusted Tech
      • Jan 2008
      • 289
      Re: MP 4001
      i would guess on development unit... the auger to its bearing/bushing
      fix the customer first then fix the machine... its simple and makes life more easy.
      • Wild Bill
        • Jul 2005
        • 774
        Re: MP 4001
        Transfer belt rides toward the rear frame and can cause squealing/ noise. also the x2 white cone shaped Transfer belt tension pulleys can cause noise also.
        Izzy
        • Counsel
          • Aug 2011
          • 529
          Re: MP 4001
          Likely the transfer belt from the 4000 to even the new 4002 models they came with crappy transfer units, of course there is a newly designed one but even our newest machines didnt come with the new design. They added a mylar at the rear of the belt frame where the belt rubs on the plastic. This is usually a squeal noise.
          • vargue
            • Oct 2011
            • 404
            Re: MP 4001
            i think that ricoh's make crap designs in transfer unit. in 3045 etc.. was the best. they don't modify nothing.
            • Gary Bowen
              Bowdog
              • Mar 2008
              • 250
              Re: MP 4001
              The MP 4000 series, MP 4001 series and MP 4002 series all have this problem as you can see from this Tech Bulletin (it is the same Transfer Unit for all 3 series).
              • amos.kaplan
                • Feb 2015
                • 19
                Re: MP 4001
                Check to see that the cleaning web is advancing. If not they build up a bunch of toner which rubs against the hot roll and is noisy as well.
                • Counsel
                  • Aug 2011
                  • 529
                  Re: MP 4001
                  That transfer belt TSB was the one i was talking about them changing it to.
                  But speaking of the cleaning web as mention above, if you hear grinding noise I have seen techs install the gear that drives the worm gear on backwards, it will go on both ways but if backwards it doesnt make enough contact with the worm gear and will skip, this will make a rubbing/grinding type noise.
                    • 37641
                    Re: MP 4001
                    Our junior tech did that just this week. He asked me if the bearing might be seized be cause there was a grinding noise and the take up roller did not seem to be turning properly. One glance at the gear and a I told it was on wrong.
