Ricoh mp 6001
  • andywong90
    • Mar 2013
    • 110
    Ricoh mp 6001
    Hello fren,anyone can tell me what problem mp 6001.while I press the green lights button power save to turn off machine.but it keep light blinking.it wont turn off.I afraid direct off Off button,it will damage hdd and ram.thank help
    • 37553
    Re: Ricoh mp 6001
    Turn it back on and wait one minute. Then try to turn it off. If the indicator continues to flash, let it flash for at least 20 seconds or more then turn off the main power.
    • andywong90
      • Mar 2013
      • 110
      Re: Ricoh mp 6001
      No,I mean the indicator light flash more than 20 min still flash,it won't off.like that how can directly turn off main power? Normally indicator light will turn off just can off main power.what problem at situation like that make it non stop flash,how to solve it. Pls help me,thanks at lot
      • Chicko
        • Sep 2015
        • 36
        Re: Ricoh mp 6001
        Seems possible damage to the hard drive or damage to the controller or ram. Try switching the machine off at the power switch in the front door and pulling out the plug. Then put the plug in, followed by holding down your # and * keys together and the turning on the switch in the front door. This should take you into a diagnostics mode and will take long to go through the process, just wait and see what it says.
        You might need to call in a technician. If you are a technician (but I doubt that you are) try testing 1 by 1 , by doing the following, (1) disconnecting the hard drive,or (2) Removing RAM and seeing if it might start up. You will need to pull the plug out in all cases and then plug in and switch. Please remember all safety at all times.
        Kind Regards
        Please again be safe. Call a technician if you just a end user.
        • andywong90
          • Mar 2013
          • 110
          Re: Ricoh mp 6001
          U mean hold down or press together button * # then power on switch?
          • andywong90
            • Mar 2013
            • 110
            Re: Ricoh mp 6001
            After pressing both # * then On power, what next step should I do? Disconnect hard disk then need to connect before I on machine? How about ram,also pull out before on power?
              • 37553
              Re: Ricoh mp 6001
              If it has been flashing for 20 minutes, go ahead and turn off the main switch.
              • andywong90
                • Mar 2013
                • 110
                Re: Ricoh mp 6001
                If it had been flashing more than 20 min go ahead turn off main power,it may be damage hard disk or ram? But usually indicator light flash awhile,it will stop flashing,that time just can off main switch,izzit right? Thanks
                  • 37553
                  Re: Ricoh mp 6001
                  By the time the indicator has been flashing for at least 30 seconds, the HDD has parked its head and spun down. RAM is not going to be damaged. If anything turning the main switch and allowing the power supply capacitors to fully discharge will clear the memory error that is causing the machine to think that a fan somewhere is still on. That is why is keeps flashing, it thinks something, usually a fan, is still running.
                  • Chicko
                    • Sep 2015
                    • 36
                    Re: Ricoh mp 6001
                    just try this,
                    switch off at main switch in the door
                    pull out plug
                    wait 1 min
                    put plug in
                    hold down both # and * keys
                    switch on
                    keep holding down # and * keys for about 30 secs
                    this should start diagnostics mode and machine will run a self test
                    if it picks up a fault it will tell you
                    if that doesnt work and you are fully qualified technician
                    switch machine off
                    remove plug
                    unplug hard drive
                    plug in and switch on
                    see if the machine now starts up
                    If the machine starts up then hard drive is gone.
                    switch machine off
                    remove plug
                    remove RAM
                    If the machine starts up then RAM is gone
                    try that
                    Please be safe and follow precautions
                    • andywong90
                      • Mar 2013
                      • 110
                      Re: Ricoh mp 6001
                      While pressing indicator button,it flashing more than 20 sec but still do not turn off.that time hard disk and ram still function ? these still working? May I know it,thanks
                      • Zoran
                        • 51
                        Re: Ricoh mp 6001
                        Repair power supply
                        • Zoran
                          • 51
                          Re: Ricoh mp 6001
                          power
