Scan Router V 2lite
  • mdfurqan2012
    • 194
    Scan Router V 2lite
    Dear All,
    I have LD118d i want to use as scan to folder which will work perfectly on winXP but user upgrade his computers to win 7 after that I unable to use as scan to folder.
    I add port TCP3670, TCP135, UDP5035.
    Configure port range 6000-6010.
    now when I scan document on machine it will show sending and then memory becomes 100% (as normally operated on winxp) but no file generates in shared folder.
    Kindly guide me.
    When I suspend delivery services from start menu an error prompt
    "unable to perform this operation since the delivery scheduler has not been started."
    Thanks for all
    • 37590
    Re: Scan Router V 2lite
    From Windows XP SP2 to Windows 7, Microsoft made a number of security changes in SMB. One change requires a user name with a password, XP did not require a password. The other will require you to update the firmware on the LD 118.
