Mpc 8002 with sc442-00
  • T911
    • Jun 2007
    • 628
    I cant get rid if thus one. I repkaced itb kift motor at rear of machine the iob the entire itb assly from anothee working machine and no luck. Ideas appreciated. It starred with a jam and the customer braking d1 lever.
  • Bantams
    • Jun 2012
    • 603
    Re: Mpc 8002 with sc442-00
    Paper stuck in the socket in the rear of the "beast" where the ITB connector plugs in is most likely cause
      • 37556
      I had a MP C6501 that was giving an error for the fusing pressure home position. Very small piece of paper was one contact on the main frame side of the connector. Paper was just large enough to cover only one contact. Had to shine my flash in to see that it was a different color than the rest of the contacts.
