ok, paper is coming thru skewed in the registration section from all 4 trays and bypass.
it seems like the registration is "tighter" on front side as the margin is gone, while the backside has one.
i have checked springs (even swapped with another 5000), bushings and buckle to no luck.
i can push on the driver registration roller to the left with a screwdriver and i can get a margin on front side.
looking at the other 5000s, seems that the bushing is in the right place.
baffling a bit.
any ideas? suggestions?
baffling a bit.
