CL7200 pattern every 4.5" printed on back of paper
  • steve@grafixsolutions.net
    • Feb 2015
    • 1
    [Misc] CL7200 pattern every 4.5" printed on back of paper
    Replaced Transfer Unit Belt Assembly and now I'm getting a 5/8" wide multi color pattern every 4-1/2" down the back side of the document. The front side of document is fine. Any ideas how to fix this? Thanks.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: CL7200 pattern every 4.5" printed on back of paper
    Transfer belt cleaning unit is a bit poorly. Strip it off and lube powder it.
    Hit it.
    • jhalfhide
      • Apr 2015
      • 451
      Is that a model where the transfer cleaner comes out with the transfer assy and you're meant to swap it to the new unit (or fit new cleaner with new transfer)?
      That's seeming likely if you say it's now only happening after replacing the transfer assy.
      • mikadonovan
        • May 2008
        • 2931
        X3. Looks like a problem with the ITB cleaning unit.
        NEVER ASSUME ANYTHING
          • 37116
          The pattern you are seeing is the ID patches used by the ID sensor assembly that has not been fully cleaned by the ITB cleaning unit. TYhey are on the back because they have been picked up by the PTR and offset on the back.
