Ricoh 820 Password Help
  • jhanda
    • Nov 2016
    • 7
    Heya,
    I posted a question in the printer section but have not gotten any responses. I'm hoping this printer might be similar enough to a Ricoh copier that the password reset procedures might be the same or very similar.
    It's a SPC820DN printer I purchased at a university auction. I am unable to log into the web interface. I have tried the admin and supervisor accounts as well as a service mode clear and I still can't get any login to work and the IP restrictions they had set at the university are still in place which makes it difficult to use. There has to be some way to reset this thing to factory settings, even if I have to reflash the whole firmware or something..
    Any assistance would be greatly appreciated!
    -Justin
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh 820 Password Help
    What do you mean by "service mode clear"?
    Hit it.
    • jhanda
      • Nov 2016
      • 7
      service mode 5801
      • TonerMunkeh
        Professional Moron
        • 3865
        Oh dear. That will have done nothing except badly confuse the machine. You'll have to get a tech in to replace the controller NVram, and possibly replace all the PCU's.
        Hit it.
        • zed255
          How'd ya manage that?
          • 1024
          There's many threads about this here already on many different models. Would be nice to have a sticky to force it to be readily seen and keep seeing 'help password reset' every couple of days.
          Performing the SP5801-01 was indeed a bad move, you have succeeded in hosing much of the settings specific to your machine and replaced them with generic defaults. Looks for a sheet of paper that is hopefully stashed on the machine somewhere we often call the 'birth certificate'. It will have all the factory 'non-default' settings that need to be re-input, or at least as many as you can. No, you won't need to replace boards or the NVRAM, but it likely will never be what it was before the clear.
          What you need to perform is SP5846-46 from 'Factory' service mode.
          No, I won't tell you how to enter this mode; it is not supposed to be for general consumption and honestly I have forgotten how to enter it on a printer anyhow. I just remember it being a specific key combination while powering on.
          • jhanda
            • Nov 2016
            • 7
            That's no good.. I read that that might not have been the best thing to do after I did it. The first thing that I landed on when I searched for it was to do 5801, after doing that and reading further I read that wasn't a good thing to do. It still prints ok after doing it, however the color registration was messed up and I had to fix that. Hopefully I can figure out what else I might have screwed up. The only thing I've noticed is that the image is skewed off center on the page, but its sharp again.
            • TonerMunkeh
              Professional Moron
              • 3865
              If you look under the jam clearance decal in the front cover you will hopefully find the birth certificate. Re-input all the values you see on there and it should come back to somewhere near good. Then we'll sort the password.
              Hit it.
              • jhanda
                • Nov 2016
                • 7
                Thank you! I got the birth certificate
                • jhanda
                  • Nov 2016
                  • 7
                  I got all the values from the birth certificate put back in. I can access service mode and special service mode.. I don't see a SP5846-46 in either. Is there yet another Factory service mode?
                  • zed255
                    • 1024
                    There are three service modes. The 'normal' SP, 'special' SP and finally 'factory' SP. Accessing each one is a little different and Ricoh does not publish how to access the 'factory' SP mode.
                    It allows access to things like serial number changes and clearing authentication among other things. For those reasons it is only supposed to be use by Ricoh's regional technical support specialists. It has been shared here for the MFPs, not sure about the printers. SP5846-46 only exists in factory SP and is not documented.
                    • sturmtrooper
                      Copier Combobulator
                      • May 2016
                      • 587
                      Replacing the NVRAM wouldn't help as the new chip would be just as blank as the old chip.
                      I asked for this to happen once and was told it would be too enabling of non technicians.
                      • TonerMunkeh
                        Professional Moron
                        • 3865
                        But the administrator and supervisor passwords would be at default, the entire point of the thread.
                        Hit it.
                        • jhanda
                          • Nov 2016
                          • 7
                          It seems to be back to printing normally, thanks for the tip on the birth certificate to get it back going. The only thing I notice odd now is that the magenta and cyan toners show as unknown with ? in the display where they were showing levels before. Any suggestions on that? They need replaced halfway soon anyway.
                          • guitar9199
                            • Sep 2016
                            • 1100
                            I'd ignore it for the time being.
                            Once you replace the cartridges with new OEM ones, you SHOULD get the display back to showing levels again.
