MPC300/400 mac driver
  • logrady2331
    • Feb 2011
    • 301
    Hello all, I might be posting gin the wrong spot, forgive me if so. I have an MPC300sr at a customer location and they have a mac. I thought P/S chip would be needed but it appears to be embedded? NOt sure where to go from here. Tried to install the PPD installer but the machine will not come up on the network. LOST........Thanks in advance.
  • LNorris
    • Sep 2008
    • 645
    Re: MPC300/400 mac driver
    print a config sheet to see if postscript is installed, then you will need the postscript driver from ricoh for that machine.
    • sandmanmac
      • 3981
      Yes, P/S is standard on those machine.
      Not a MAc expert at all, but if you go to add a printer, it should find it and be a pretty automatic process. No driver downloads have been necessary any time I've done it
