Ricoh MP 5000B TD Sensor initialization failure
  • Zia Graphy
    • Aug 2012
    • 17
    Hiya folks. I'm working on an MP 5000B. Just replaced the developer and developer unit to address recurring toner "dusting" (machine had an old style developer unit). However when attempting to run the TD sensor initialization SP 2801, I get the message "failed". My understanding is that this is caused by an old engine firmware, which has never been updated on this machine.
    Would anyone be kind enough to send me the engine firmware for this unit? Thanks in advance for any assistance!
    • 37635
    Re: Ricoh MP 5000B TD Sensor initialization failure
    I could be a bad TD sensor on the development unit. Does the development unit you put in work in another machine?
    • jonhiker
      • 661
      there is a tech bulletin on that issue. you are correct, you will need to update the firmwareto get rid of the failed message. In all actuality, that is a false "failed" message... it really did work.
      • Zia Graphy
        • Aug 2012
        • 17
        I haven't tested the developer unit in another machine, as it is 1) a new replacement part from ricoh and 2) this is the only instance of this machine that I've got in the field. I'm hoping they didn't send me a defective part, but you never know.
        Thanks for the confirmation! Any idea if it is a false "failed" message, does that mean the TD sensor correctly initialized and it will work and all of the voltages will be correct (vsg, vsp, yadda yadda)? In other words, is this just an annoying message that I can ignore, or am I going to run into problems if I don't update the firmware?
