2035 e faxes are received to file
  • Rick
    • Mar 2007
    • 277
    This one customers machine is receiving their faxes to file instead of imeadietly printing them out . I checked the settings and do not see where ive gone wrong .any Ideas anyone ?
  • E Winter
    Check this setting:
    User Tools > Fax > Key Op > Received File Settings (can be switched between "print" or "store")
    I only know the german wording so it's translated by me and may appear not 100% like this but I'm shure you will find this setting.
    • copyman20
      • 207
      Is it forwarding at the same time its printing? If that is the case and you don't want it to print, go to the parameter setting, sw 11 bit 6 change from 1 to 0.
      • nmfaxman
        • 1702
        RTFM
        It is in the user manual.
        Download the PDF file and do a search for output settings.
