blue color in not printing in spc420dn
  • vargue
    • Oct 2011
    • 404
    [Misc] blue color in not printing in spc420dn
    hi fellas yesterday my customer told me that blue color in not reveled in page . i went there and test page also not revealed .all colors full. and no add toner signal did any one see that befor
  • davel
    • Oct 2011
    • 1095
    Re: blue color in not printing in spc420dn
    Yes. What did you check.
    • vargue
      • Oct 2011
      • 404
      a777777777777777777777a
      • eddy out
        • Oct 2016
        • 359
        I have had a pcu do this before on this machine.
        • Mark Bbb
          • Jun 2012
          • 1662
          Remove all pcu's and transfer unit, clean and check all, reinstall...
          Same issue?
          Perform music
          • TonerMunkeh
            Professional Moron
            • 3865
            Preferably something by The Commitments or Elvis.
            Hit it.
            • DougD
              2020 Retired
              • Sep 2016
              • 76
              Here are some ideas to help you get started.
              • Iowatech
                Not a service manager
                • 3930
                Do you know if there was a new cyan PCU installed in that machine recently?
                If that isn't the case, what follows is probably wrong and stupid, sorry about that.
                If the cyan PCU was recently replaced, it could have been stored in a place that had excessively hot temperatures, which can cause the toner in the developer to soften. Then when the PCU is moved to a place with more appropriate temperatures the toner will solidify, which will cause the developer to turn into a solid rather than the powder it is supposed to be. As the developer is hardened over the TDS, the machine will never detect that it needs to add toner, but the color supplied by that PCU will be absent.
                Sorry, I wasted an entire day on a different manufacturer's machine with this very same problem, so I think that is pretty important.
                It also could be caused by a fault in the PCU drive (if the drum or developer roller aren't turning this type of problem can happen) or the drum ground (if the laser can't discharge the drum, no toner will be attracted to the drum).
                • tcs04
                  FORMER Techie
                  • 1183
                  Elvis has left the building!
