Looking for Ricoh MP 3352 Doc Feed part number
  • Foo
    • Nov 2009
    • 199
    I am working on a MP 3352 doc feed. The gray top cover comes off and there's an inner cover that is tan colored. The inner cover is the part that the hinge pins(screws) go through. This cover is broken where the hinge point screws go through causing odd problems. I'd like to buy that inner cover(I have no idea its proper name) and I need a part number to do that.
    Or...if I had a parts manual, hint hint, for the doc feeder I could avoid coming on here and bothering all of you fine fellow technicians and yes...I have spent some time on Google but I can't come up with a safe download I feel good about.
    Ricoh Product Code: D578
    Name: DF3060 Document Feeder
    Thanks for any help you can give me.
    Jeff in STL
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: Looking for Ricoh MP 3352 Doc Feed part number
    Attached.
    • Foo
      • Nov 2009
      • 199
      Thank you for that.
      Just did some digging using P/N D578 4911
      I didn't find a source for that part.
      I'll keep looking, maybe P.R. can order it for me.
      Thanks again!
      Jeff
        • 37494
        You can get a complete DF3060 at recycledparts.us.
        RICOH Document Feeder
        • Foo
          • Nov 2009
          • 199
          Used your link and did purchase one.
          Worked and looked great.
          Jeff
