I just looked that up and that machine appears to be a MFD, so you might want to post your question here: http://www.copytechnet.com/forums/ri...tetner-lanier/
The majority of Ricoh techs can be found there, and unlike me most of them work on the newer machines.
Good luck!
SC545: Heating Lamp Full-Power Error
The fusing lamp is fully-powered for a certain time while the fusing unit stays in the stand-by mode and is not rotating. Posible cause:
Deformed thermistor
Thermistor not in the correct position
Defective fusing lamp
Replace:
1. Replace the fusing unit.
2. Replace the fusing lamp. Note:
Execute "Engine Maintenance Menu" to recover the machine after completing the recovery procedure. Otherwise, the machine continues to issue this SC code and cannot be operated.
