aficio 2045
  • Gab
    • Aug 2015
    • 676
    aficio 2045
    I want to connect this machine to computer. I have controllers from other from other af 2045 machines.
    If i put one of these controllers to this machine and try to print through network i know an error code appears .
    Can it print through parallel port? What can i do to print through network?
  • davel
    • Oct 2011
    • 1108
    Re: aficio 2045
    buy a printer that does not belong in a museum
    • Lagonda
      • Aug 2008
      • 1649
      Re: aficio 2045
      It's been a long while since I have seen a 2045 and I sort of remember that you need a Print/Scan SD card. If you don't have one of those you are not going anywhere.
      But as Davel says this copier is very old and outdated. They were never a good model to start with so save yourself a lot of heartache and find something a lot newer.
