ricoh 1027 transaction problem
  • vga_man
    • 78
    [Misc] ricoh 1027 transaction problem
    Hello everybody!
    I've this problem with my ricoh 1027 when printing or copying using any tray the copy text moves from the center of the paper.
    Seems that registration cl does not work properly but checked it and found that it work.
    You can see my attachment.
    Any help please!
    Sorry for my bad English!
  • Iowatech
    Not a service manager
    • 3930
    Re: ricoh 1027 transaction problem
    If you haven't physically inspected the clutch, do so at your earliest convenience. If you see the brown dust of doom, that clutch is worn out even though it may appear to test well.
    For what it is worth, a brownish color around clutches indicates that the internal metal clutch parts are probably worn and failing.
    If you've already looked at the clutch and it is perfectly clean, I'm sorry for wasting your time.
    • laitang
      • Nov 2012
      • 627
      Your attachments aren't clear, perhap the registration stuck!
      • vga_man
        • 78
        Thanks alot!
        I replaced it and the new one works well.
        Now suffering from drum dots ;-)
        • vga_man
          • 78
          Sorry i've Chinese mobile phone camera :-)
          • rthonpm
            • Aug 2007
            • 2858
            Check the lens: it's probably just dirty.
              • 37513
              Thanks alot!
              The only solution for drum spots is to replace the PCU.
