Ricoh 907EX Web not turning.
  • jimmycabral
    • Jun 2016
    • 35
    [Misc] Ricoh 907EX Web not turning.
    I have Ricoh Pro 907Ex have problem in web rotation. It don't turning cause the toner accumulate and print make line. Anyone have Idea where i can test in SP mode the DC Motor: Cleaner:
    Your input is appreciated.
    Jimmy Cabral
    KSA
  • totoro
    • 568
    Re: Ricoh 907EX Web not turning.
    sp 5804-034 is the web motor output check.
    Totoro
    • jimmycabral
      • Jun 2016
      • 35
      Thanks to the reply, the motor not working...i order for the replacement.
      Appreciated.
      JC
      • Imprestik
        • Aug 2012
        • 297
        If that doesnt resolve your issue it's time for a I/O board
        I have had this issue a fair few times
        • jimmycabral
          • Jun 2016
          • 35
          Hello Guys,
          I got the web Motor and doesn't work it do the same thing(not turning). As mentioned that i need to replace the I/O but there is any other possible part needed to be replace? My worry is It could damage my Upper Fuser Roller if not being fix.
          JC
