MP4000spf Dog Ear Iintermittent
  • Wild Bill
    • Jul 2005
    • 774
    [Misc] MP4000spf Dog Ear Iintermittent
    Im not sure why because the images I have are JPG but I couldn't upload them it says invalid, so I did it as a file share from google drive. but not sure if you will be able to see the pics
    Any thoughts?
    Izzy
    • 37532
    Re: MP4000spf Dog Ear Iintermittent
    Sounds like you might have a small scrap of paper in the tray 1 feed unit.
    https://drive.google.com/file/d/0BwT...ew?usp=sharing
    There is a size limit on all image files. Data size: 976.6 KB, Image size: 620X280, file must meet both requirements. I use Irfanview to resize my image files to be within the 620X280 requirements.
    • fshead
      • 2376
      on these ODD happenings i have found:
      a nick on a plastic guide,a missing rib,
      or a small piece of paper or label that i missed...
      i dont have any of these to service so i cant say
      if this pertains to you..good luck
      • davel
        • Oct 2011
        • 1107
        check the paper dust collector assembly.
        • Iowatech
          Not a service manager
          • 3930
          This is probably wrong, but based on the pictures it looks somewhat like the transfer belt unit might have something to do with this.
          Just my take, but if that was caused by the registration roller, I would kind of expect there to be more evidence of creasing in the blank streaks on the "dogear 1" picture. The fuser on that machine is pretty good at ironing many creases flat, but I'd expect to see more if that was only run through the fuser once.
          I suppose if time permits you might want to check the guides leading into the transfer belt unit area, and maybe remove the belt from the unit and look for a build up of toner on the rollers (toner build up on the rollers in the transfer belt unit was kind of common on that chassis).
          • Mark Bbb
            • Jun 2012
            • 1662
            image is skewed on paper => paper leaves paper tray skewed.
            Happens before the fusing unit, even before reg. rollers =>
            check paper tray and paper stack.
            Is the problem one side only?
            Landscape, you mean LEF or SEF (these are better terms than landscape or portrait)?
            • Cipher
              It's not easy being green
              • May 2006
              • 1309
              I've had a broken plastic guide in the exit unit, which couldn't be seen until exit unit was remove and top was taken off.
              I've had missing plastic exit guides leading into the bridge unit.
              I've had a metal plate next the reg roller bent out.
              I've had a warped fusing entrance guide.
              I've had a whole sheet of paper drop pass the rollers behind the LHS door cover.
              I've had a partial obstruction behind the transfer unit right in the bottom where you can't see shit.
              I've had broken tray side fences / side fences that don't align to the centre.
              I've had staples and papers clips in the bridge unit and finisher entrance.
              All those had caused dog earing for me on the Alex range at some point.
              Also worth noting the machines interweave when duplexing unless letterhead mode is invoked.
              I mention it as the dog earing may be occurring in the duplex path, but the fold and print indicate otherwise.
              • Coptech
                worker drone
                • 460
                Just my opinion but judging from the print on the folded edge, it is prior to the drum/transfer, and assuming it is a single sided print, the fold inwards suggests that the catching protrusion is on the drum side of the machine and not the transfer side. I would think it would almost have to be the vertical guide or even the top edge of the paper tray. The bottom "lift plate" in the tray isn't bent down on one side is it?
                  • 37532
                  Since it only happens with tray 1 and you have replaced the tray 1 feed module (usual cause of dog ears on only one tray) you might check to see if the guide rail(s) for the tray might be loose.
                  • Wild Bill
                    • Jul 2005
                    • 774
                    Another tech went out on this and said there were some nicks on the tray 1 guide that folds in and out on the feed assy. Kinda weird cause I replaced that. We will see Thanks for all the help everyone! Also, Forgot to mention I Replaced the paper dust collector assembly and also I replaced the Entire Transfer belt assembly.
                    I replaced the entire paper tray but ill look at that rail that it slides into. You guys are very helpful and I really do appreciate it. I'm thinking the guide he ordered is NOT going to fix this... Call it my copier tech intuition. Ill keep you posted. Thanks Again!
                    Izzy
                    • JonManchester
                      Technician / Shop Manager
                      • Aug 2013
                      • 103
                      I have had this issue before on a MP4000 and my dogears were caused by the metal frame just above the registration rollers and next to the pcu. Ours was that rail next to the pcu was bent and we either bent it outwards or inwards cant remember its been awhile. I found that fix on here somewhere years ago.
                      Live for something or die for nothing.
                      • Wild Bill
                        • Jul 2005
                        • 774
                        This was the problem. It was crashing into the pcu. just barely nicking it so it was intermittent. It was was bent inward. This guide is easily bent Ill be looking for it now. Evened it out and YAY!!!
                        I don't know why I didn't see it, I must have had tunnel vision.
                        Thank You!!
                        Izzy
