Pro C901 SC412
  • DanaNL
    • Nov 2016
    • 25
    Pro C901 SC412
    Hello,
    hope u all had a good new years evening.
    I have a Ricoh Pro C901 but somehow i cannot find the potential sensor in the PartsCatalog.
    the machine gives SC-412 any solution would be apreciate it.
    thanks in advance,
  • totoro
    • 568
    Re: Pro C901 SC412
    From the service manual
    sc 412 D ID sensor error: Development gamma M
    Development gamma for black, magenta, cyan, or yellow is not
    within range (0.3 to 6.0). Process control halts when this SC is
    issued.
    ID/ MUSIC sensor shutter defective
    LD sensor harness loose, broken, defective
    LD unit not firing
    CGB HVPS harness loose, broken, defective
    CGB HVPS defective
    Developer worn
    Check the result of process control with SP3-821-001.
    Result code: 55 or 59
    Replace the developer.
    Result code: 56
    1. Clean the dust shield glass of the LD unit.
    2. Replace the CGB HVPS.
    Result code: 61
    1. Check the harness connection to the LD unit.
    2. Replace the LD unit.
    from parts manual frame section 2
    G178 2549 Electric Potential Sensor
    from GG June 2016
    SC 412 ID sensor error M - ID/MUSIC sensor shutter defective
    SC 412 ID sensor error M - ID/MUSIC sensor defective
    SC 412 ID sensor error M - CGB power pack defective
    Happy New Year to you and hope that helps.
    Totoro
    • DanaNL
      • Nov 2016
      • 25
      Re: Pro C901 SC412
      Thank you verry much!
