Please Wait on a brand new MP 7503
  • Roger67
    • Nov 2013
    • 84
    Hello Folks,
    i have a brand new MP 7503.
    After Updating the Cheetah and JAVA Firmware i tried to update the
    Maschine FW.
    When the first Window shows to select the different FW the Maschine
    changed to a black Screen and shows a "Please Wait "which will never stops.
    I changed the Controller Board and the HDD,without success.
    Any has an Idea ? Maybe the IUP Board '
    Roger
  • Roger67
    • Nov 2013
    • 84
    Re: Please Wait on a brand new MP 7503
    Hi Folks,
    i already changed the Controller Board,the PCB-BICU and the PCB-IOB .
    I also checked the Harness between the OP and the BICU,everything looks O.K.
    Now i ordered a new OP,which cost a lot.
    I can update the Cheetah with the SD Card without any Problems but i still get the
    Please Wait on Screen after Startup and after the Blue-Picture.
    After that its not possible tp shut down the maschine you need to diconnect the
    Power Cable.
    Nobody any Ideas ?
    Greetings
    Roger
    • davel
      • Oct 2011
      • 1107
      is sd card in machine slot or in SOP.
      • TonerMunkeh
        Professional Moron
        • 3865
        It sounds like the Cheetah panel firmware update failed. Use the package firmware update method to do the lot again.
        Hit it.
        • Roger67
          • Nov 2013
          • 84
          Hmmm,the maschine comes without any SD card inside.
          ( It sounds like the Cheetah panel firmware update failed. Use the package firmware update method to do the lot again. )
          ...package FW Update-Method..?.........I dont now how to do that,i have no conection to the Maschine.
          Greetings
          Roger
          • TonerMunkeh
            Professional Moron
            • 3865
            You can get the package from my-ricoh. It's down the bottom of the download page. When it's down, put it in a folder called "package" on a blank SD card and put it in slot 2 on the machine. From there, it will update the machine firmware and the Cheetah panel too.
            Hit it.
            • Roger67
              • Nov 2013
              • 84
              Hmmm,
              thanks for the Tip,but i cant find the link in My Ricoh...................
              They are 71 Posts for the MP 7503....
              A lot of Firmware Notes.....but no usable Download Link for the Deep Firmware.
              Roger
              • paulg
                • Jun 2007
                • 278
                This is the link Ricoh Uk supply on TDC2 https://www.my-ricoh.com/Portal/Publ...d-ad41fedc256dJust make sure you are logged in to my-ricoh.com
                • Roger67
                  • Nov 2013
                  • 84
                  So,
                  the Package-Firmware doesnt fix the Problem.
                  Finally i changed the OP and after a Factory Reset of the Panel the
                  update of the Package FW was functionall.
                  Now its looks good.
                  Maybe with the old OP,a Factory Reset wil fix the Problem too.
                  Roger
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    Would the panel let you into recovery mode?
                    Hit it.
                    • Roger67
                      • Nov 2013
                      • 84
                      Yes,if the Chettah-update SD is in the Panel.
