MP301spf fax tone
  • tufbnme
    • 493
    MP301spf fax tone
    All the volumes are turned up, cannot hear the on hook dial tone or any fax tones. Is there a switch to turn it off?
  • davel
    • Oct 2011
    • 1104
    Re: MP301spf fax tone
    Test the line with a telephone.
    • tufbnme
      • 493
      I should have mentioned that it sends and receives fine, just no sound.
      • tufbnme
        • 493
        OK...which SP are you referring too?
        • Elmo
          • Feb 2010
          • 541
          This was all i could find in the manual
          G3 Switch 00 [SP No. 1-105-001]
          No FUNCTION COMMENTS
          0-1
          Monitor speaker during
          communication (tx and rx)
          Bit 1: 0, Bit 0: 0 = Disabled
          Bit 1: 0, Bit 0: 1 = Up to Phase B
          Bit 1: 1, Bit 0: 0 = All the time
          Bit 1: 1, Bit 0: 1 = Reserved
          (0, 0): The monitor speaker is disabled all through the
          communication.
          (0, 1): The monitor speaker is on up to phase B in the T.
          30 protocol.
          (1, 0): Used for testing. The monitor speaker is on all
          through the communication. Make sure that you reset
          these bits after testing.
          Bit Switches
          225
          I Used To Live To Fix Things Now i Fix Things To Live
          • davel
            • Oct 2011
            • 1104
            Is the speaker connected.
            • tufbnme
              • 493
              Re: MP301spf fax tone SOLVED
              The connector between the speaker and fax module was cracked. Couldn't see it until I pulled it out. Factory defect apparently, the machine has only 9k on the clock
              • tufbnme
                • 493
                Got it to work
