FX10
  • T911
    • Jun 2007
    • 628
    FX10
    Anyone have the procedure for the fuser reset on this one. thanks much
  • sandmanmac
    • 3985
    Re: FX10
    WOW...I had to dig deep for this one!
    If you still need it:
    When a service call was caused by a fusing unit failure (codes 0X):
    The same code is stored at address 80032C(H).
    After fixing the problem, reset the data at address 80032C(H) to 00(H), then restart the machine
    to clear the service call. Ram Display_Rewrite.pdf
