Aficio CL 4000dn Color streaking
  • stevee104
    • Mar 2007
    • 214
    Have attached some samples of the issue, change transfer belt but didn't solve problem. Thought because it was
    not cleaning and putting the color lines that was transfer belt and not the drum units. Am i going to have
    to change all three imaging units or is there a fix for it clean the laser slit glass also.
    Total count is 48519 23887/24832. Didn't know if drums had pcr charge rollers that could be clean.
    Lines are running length of page.
  • LNorris
    • Sep 2008
    • 645
    Re: Aficio CL 4000dn Color streaking
    is there a transfer cleaning unit on that?
    • stevee104
      • Mar 2007
      • 214
      No it's on the transfer belt itself
        • 37532
        Looks like a dirty charge roller on the cyan drum unit. Might be caused by an excessively worn lube bar. Best solution is to replace PCU.
        • stevee104
          • Mar 2007
          • 214
          Also has yellow and magenta on the prints so are we looking at all 3 pcu , never seen all 3 quit at the same time.
            • 37532
            For most customer serviceable color printers, Ricoh sells a maintenance kit that includes 3 color PCUs. Projected yield is 50K. If you are less than 80% of yield, you can try cleaning charge rollers though you are experienced at cleaning charge rollers, you could make matters worse.
            • stevee104
              • Mar 2007
              • 214
              How hard is it to get to the charge roller on these units, i do not have service manual on this machine.
              • TonerMunkeh
                Professional Moron
                • 3865
                The drums split apart quite easily but just save yourself the hassle and fit a set of PCDU's.
                Hit it.
                • stevee104
                  • Mar 2007
                  • 214
                  OK finally got pcu units in yesterday and installed them.,when i cut machine back on
                  it threw a sc325 which is a color motor lock so first one i tied was the magenta and the new one was the
                  problem. So with the old one in the machine it went into calibration and to ready state, so i cut the machine off got the new
                  magenta unlocked, reinstalled it but it did not re calibrate and now it throws a sc361 after a few copies,
                  is there any way to get this to reset the toner sensor in the service mode or the unit toast.
