MP 2000 output in wrong orientation
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Have a customer who says that the machine will at random output the image SEF, machine has 8.5x11 LEF in tray one and 8.5x5.5 LEF in tray two. Haven't observed it myself so I'm not sure what could cause it. Paper size/orientation sensor under glass seem to be working properly. Not the first time they have mentioned this.
    Could be user error but I'm not really sure.
    Ideas?
  • sandmanmac
    • 3978
    Re: MP 2000 output in wrong orientation
    Dirty sensors on the adf feed table? or maybe the sensor board itself on the table could be a little 'gunked" up
    Just a guess...
    • NeoMatrix
      Senior Tech.
      • 3514
      Printing ,copying or Fax ?
      Could it be a print driver custom setting when printing from PC ????
      • TonerMunkeh
        Professional Moron
        • 3865
        Rotate sort could be enabled in the driver. Is the image rotated correctly on the SEF output?
        o_1600l2ps.pdf
        Hit it.
        • mikadonovan
          • May 2008
          • 2931
          Could be they are copying an off size document off the glass with incorrect scan settings.
          NEVER ASSUME ANYTHING
          • sturmtrooper
            Copier Combobulator
            • May 2016
            • 587
            Copy only, this machine does not have the print option installed. I don't remember if it has a fax but they only mentioned it happening while making copies.
            I'll check the ADF paper size sensor as well next time I'm there.
