Ricoh Aficio 1013 Ricoh MP201 Ricoh MP301 Heat roller
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    Does anybody know if the heat roller for Aficio 1013 fits the MP301 model? and the pressure roller?
    as far as I know it does for the MP201, althought it looks different from the outside to a Mp301,
    Thanks for inputs
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    Re: Ricoh Aficio 1013 Ricoh MP201 Ricoh MP301 Heat roller
    I Just solved it,
    all OK.
    thankyou all.
    • tufbnme
      • 493
      So you solved it...Whats the answer? We're all wondering.
      • Xcelsior
        Ex-Tech
        • Jan 2017
        • 24
        The following parts are unique for D127/D128. When replacing the following parts, usethe parts specified for each model. DO NOT mix up the following parts for D115/D116and D127/D128. Otherwise, both of the machine operation and output quality are notguaranteed.
        1. LED Scanning Unit (Scanner Unit)
        2. Laser Unit (Writing Unit)
        3. ARDF
        4. Pressing Roller (Fusing Unit) AE020207
        5. Toner Bottle (Toner Supply Unit)
        6. Operation Panel
        7. Bank Unit Motor (Optional Bank Unit)
        8. One Chip Microcomputer (Engine Control)
        The Following Item(s) are Common to other models;
        AE011131 Hot Roller (D115 / MP 201SPF)
        In regards to the 1013, it's potentially possible, but as with the 201/301, quality/performance is not guaranteed even if it does fit.
        Previous Ricoh Field Service Tech II - November 2017.
        • copyaction
          • Oct 2007
          • 991
          Originally posted by rapidocument
          I Just solved it,
          all OK.
          thankyou all.
          and.......
          • rapidocument
            Multibrands Tech
            • Jul 2012
            • 381
            I solved the situation offering the customer a different machine
            so is not related to the original question
            that's why I didn't post a follow up,
            thanks anyway.
