Pro 1107EX 2nd side original skew
  • ricmartinho
    • 142
    Hello there!
    I have this Pro 1107 that skews the second side of the originals.
    I tried to adjust with SP6006-6 (Reg Buckle Adjustment: Back Side from -29 to +29) and the image stays exactly the same.
    1st side: 1st_side.pdf
    2nd side: 2nd side.pdf
    I've taken out and cleaned the Exit guide unit, the Guide plate and the sensors but the image still skews. I've also adjusted the position of the ADF to no avail.
    Any tips?
    I've another machine and I will try to swap the exit guide unit.
  • ricmartinho
    • 142
    [SOLVED] Re: Pro 1107EX 2nd side original skew
    Forgot to post about this one.
    After all it was already doing a small skew on the 1st side which got worse on the 2nd side. I forgot to check the registration sensor.
    Cleaned it and it was OK.
