Ricoh Aficio MP 6500
  • Vladika
    • Dec 2016
    • 40
    Hi, I have a problem with the cleaning web. The user manual writes me that the cleaning web is changed to 300K, but did not go three days she was winding the whole. This happened to me twice recently. Ricoh Aficio MP 6500
  • tjvincent
    • 280
    Re: Ricoh Aficio MP 6500
    Your web motor is staying on, probably pinched wire harness which happens if it's not installed correctly.
    • Vladika
      • Dec 2016
      • 40
      Thank you
        • 37533
        I jave had this happen from stripped gears on the web drive train, worn friction pad, and loose motor mount.
        • Codex
          • May 2008
          • 704
          Had the same with pinched wire... Close the front door and you can hear the web motor if it stays always on.... You hear an "klick, klick" every 5 seconds
          Inviato dal mio SM-G935F utilizzando Tapatalk
          Memento Audere Semper
          • Zoran
            • 51
            Repair iob mp 6500
            replace smd tr. Q23
            • Zoran
              • 51
              Vladika pozdravi Scepanovice iz Podgorice
              • Zoran
                • 51
                I promeni motoric da ti ne bi stradao tranzistor
