Default Duplex mode
  • mdfurqan2012
    • 194
    Default Duplex mode
    Dear All,
    I have MP4001 on which duplex mode is selected by default.
    every time when i make single copy i have to deactivate duplex function.
    kindly guide me how can i make duplex off by default.
    i also face this problem in MP2851, MP2550, MP5001 etc.
    thanks
  • guitar9199
    • Sep 2016
    • 1100
    Re: Default Duplex mode
    Configure all the settings you would like to have as defaults, then press the "Program" button on the control panel and select "Program as Default".
    • mdfurqan2012
      • 194
      I want to do it default as in previous model by default duplex is off you have to on for double sided copies.
      • Xcelsior
        Ex-Tech
        • Jan 2017
        • 24
        As Guitar mentioned, set the settings on the copy screen as you want them then hit "Program" and then "Program as Default". Once that's done the Copy screen will default to those settings after time-out or after hitting 'Clear'.
        Ricoh Guide on setting defaults on the Copy/Scan screen.
        Previous Ricoh Field Service Tech II - November 2017.
        • mdfurqan2012
          • 194
          Thanks for all
          I will try it tomorrow
          Once again thanks
