MPC3000 SC543
  • Wind Cool
    • May 2014
    • 82
    MPC3000 SC543
    Hi.
    Im been facing error code of SC543.
    According the manual said that it is the PSU, BICU or IO board problem. But i suspect mostly is Fusing Unit because i had change the BICU board before.
    May i know other issue might effect? How to solve this problem?
    tq.
  • Polarbear
    • Feb 2012
    • 1070
    Re: MPC3000 SC543
    Hi
    have you checked the heating roller fusing lamp for continuity? Also the thermal fuses in the same circuit.
    What the code means is that the lamp circuit is staying on for too long without the thermistor reading the target temp.
    Press the GREEN button!!
    • Wind Cool
      • May 2014
      • 82
      Re: MPC3000 SC543
      Originally posted by terramobil
      What happend when you login to service mode and try to reset SC543?
      i had reset. but still happen after 5 days later.
      • TonerMunkeh
        Professional Moron
        • 3865
        Re: MPC3000 SC543
        The only cure for SC543/553 is to replace the complete fuser with a new one.
        Hit it.
